2001 Toyota Corolla 2001 Corolla noise when I brake with ge
2001 TOYOTA COROLLA
84,000 MILES • 4 CYL • FWD • AUTOMATIC
ROCKJEONG
I have 2 questions.
1. From yesterday, I feel vibration and hear unusual noise from engine when I brake at traffic light. I tried with the gear in neutral, reverse and parking. The same thing happened with reverse, but a lot less vibration and noise in park and neutral position. Vibration and noise grow until I feel and hear after braking. I checked engine oil level which was low but still acceptable. No engine check light. It seems to be worse as engine gets warmer.
2. For 3-4 years, I have been having starting problem under very cold weather (Minnesota). When engine is cold, it gets turned on, but very low idle, then 1-2 seconds later, makes "click" sound from I think under my feet, then engine seems to idle in a normal way. But no problem after engine gets warmed up.
Do you think this problem is related with the above one?
Thank you for your help.
Sincerely,
Peter
Jan 25, 2009 at 12:59 AM
