2001 Toyota Corolla
MSKUMON
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 148,000 MILES
How do I know if the piston is burned
Saturday, May 30th, 2009 AT 8:58 AM
MMPRINCE4000
  • 8,548 POSTS
Perform a compression test, if piston is burned, compression will be significantly lower.
It would be unusual for a burned piston in a Toyota. Generally it would be caused by a very lean A/F ratio and if just one cylinder, most likely a fuel (lack of) issue on that cylinder. It is also possible the piston was a bad casting to begin with.
Sunday, May 31st, 2009 AT 7:07 AM
