2000 Toyota Corolla WHITE SMOKE
79,000 MILES • 4 CYL • FWD • AUTOMATIC
ROMELLO1
WHEN I START THE CAR WHITE SMOKE COMES OUT THE EXHAUST THEN IT STOPS AFTER 5 TO 10 MINS. WHAT IS THE PROBLEM HELP PLEASE.
Apr 7, 2008 at 2:28 AM
  • 75,988 POSTS
Condensation/moisture-might want to replace the PCV valve.
Or get the cooling system block and pressure tested this will tell you something such as blown headgasket cracked head and block
Apr 7, 2008 at 2:34 AM
