HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Exhaust
White Smoke
2000 Toyota Corolla WHITE SMOKE
ROMELLO1
MEMBER
2000 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
79,000 MILES
WHEN I START THE CAR WHITE SMOKE COMES OUT THE EXHAUST THEN IT STOPS AFTER 5 TO 10 MINS. WHAT IS THE PROBLEM HELP PLEASE.
Monday, April 7th, 2008 AT 9:28 AM
MECHANIC
Condensation/moisture-might want to replace the PCV valve.
Or get the cooling system block and pressure tested this will tell you something such as blown headgasket cracked head and block
Monday, April 7th, 2008 AT 9:34 AM
Please
login
or
register
to post a reply.
Related White Smoke Content
2003 Toyota Corolla White Smoke From Engine
I Did Not Change The Engine Oil For Years And White Smoke Came From The Engine. I Went To A Repairer Who Flushed 3 Times With Engine Oil And...
Asked by
tomlilomo
1 ANSWER
2003
TOYOTA COROLLA
GUIDE
White Smoke
There are different levels of white smoke/steam which could be a normal occurrence. A small amount of water is produced as a normal bi product of the combustion process and...
White Smoke From Engine Only On Petrol
Hi My Car Is Giving White Smoke Continuously Not Only On Startup. This Only Happens If Car Is Running On Petrol On Cng (compress Natural Gas...
Asked by
mianjan95
2001
TOYOTA COROLLA
1991 Toyota Corolla White Smoke
Ever So Often I Turn On My Car And See White Smoke Out Of My Exhast Pipe, But It Doesnt Happen Everytime I Turn On My Car, Whether Its...
Asked by
sbhsdrummer
1991
TOYOTA COROLLA
White Smoke Through Exhaust Pipe
I Have Two Cars. One Of Them Gives White Smoke In Morning Time In Winter Season But The Other Do Not. Which Of Them Has Something Bad Or...
Asked by
ali.alvi
2007
TOYOTA COROLLA
White Smoke
I Bought This Car From A Tow Yard Four Days Ago. I Noticed The Speedometer Did Not Work Until Sixty To Sixty Five Mph, And The Temperature...
Asked by
Shawnte Wells
1 ANSWER
1993
TOYOTA COROLLA
VIEW MORE
Exhaust System Removal
Catalytic Converter Replacement
Oxygen Sensor Test
