2000 Toyota Corolla Sluugish when cold
RANDYJANEWAY
Engine Performance problem
2000 Toyota Corolla 4 cyl Automatic 152000 miles
Very sluggish starting from a stop at times, especially when cold. Just replaced plugs, cleaned throttle body, replaced air filter. Which sensor would cause this (tp, ect,....)?
Jul 24, 2009 at 7:17 AM
MMPRINCE4000
  • 8,548 POSTS
Many sensors could cause it, but you should have a check engine light?
Jul 25, 2009 at 12:45 AM
RANDYJANEWAY
No check engine light. It only happens when cold and when just starting from a stop the first time; press on gas, and it takes a few seconds to respond.
Jul 25, 2009 at 4:42 AM
MMPRINCE4000
  • 8,548 POSTS
Measure fuel pressure with mechanical gauge and spark with a calibrated spark tester.
Sensors, like TPS, IAC, Coolant would set a code if out of range.
Jul 26, 2009 at 12:56 AM
