2000 Toyota Corolla Signal lights
2000 TOYOTA COROLLA
135,000 MILES • 4 CYL • FWD • AUTOMATIC
FRYER
I have a strange problem. My turn signals and hazard lights do not work. If I turn the hazard light switch to the on position the signal lights work normally.
May 12, 2010 at 12:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
so the turn signals only work if the hazard switch is turned on? most likely due to wiring issue, check the wiring at both the hazard and the turn signal switch.
May 12, 2010 at 12:48 PM
