2000 Toyota Corolla Rear strut replacement and alignment
119,132 MILES • 4 CYL • FWD • AUTOMATIC
BRIAN777
I already replaced my front struts and then went to get a front wheel alignment. Now i was going to replace the rear struts once i had enough money to replace them, but found out I may need another alignment if i do. Is this true? Some say i do, some say i don't. Not sure what to believe. Also should i replace the sway bar links while i'm at it since there attached to the strut?
Thanks
Sep 5, 2009 at 12:09 PM
MMPRINCE4000
  • 8,548 POSTS
Whenever you replace struts, you should get it aligned, especially camber.
I would replace the links, they are probably pretty rusted by now.
Sep 6, 2009 at 2:04 AM
