2000 Toyota Corolla Oil Problem
SHMA0701
  • 2000 TOYOTA COROLLA
2000 Toyota Corolla Automatic 115K miles
Hi, My car consumes oil too quick. I have to add oil so facst like after 200 miles. Prvously from diagnosis they change oil valve but still problem exists. Some of people are guessing motor to be damaged. But engine is too smooth. What ould be the reason? And if I have to replace motor what would be the reasonable pice with labor charge?
Could you please help me out?
Friday, March 27th, 2009 AT 12:10 PM
What you need is an engine compression check to determine if its valves/rings/cylinder wear problem.
Friday, March 27th, 2009 AT 12:33 PM
WILLIAM OLIVER
  • 25 POSTS
Do rings. I 95 % sure will fix the problem
Saturday, March 28th, 2009 AT 10:08 PM
Get an engine rebuild this is your last option to fix the problem.
Sunday, March 29th, 2009 AT 2:54 AM
