It is either leaking it or burning it.
Check for leaks first. If compresion is good, it may be the valve stem seals.
I would also have a leak down test performed, this will tell you if rings, valve seals are worn.
Also remove O2 sensor, plugs and check for oil fouling.
SPONSORED LINKS
Monday, July 20th, 2009 AT 8:23 AM
