2000 Toyota Corolla Engine Using Oil
17,300 MILES • 4 CYL • FWD • AUTOMATIC
WDEMERY
Just bought this car, as is. Checked oil after 2 weeks.
2 quarts low. Filled. Checked again 8 days later. 1 quart low. No significant smoke out the tail pipe. Car seems to have plenty of power. A little sluggish on start up. When purchased, the car needed a catalytic converter, changed that. Could burning oil have caused the converter to go bad and any suggestions as to where my oil is going. No visible leaks on the engine block.
Oct 3, 2008 at 10:50 AM
MMPRINCE4000
  • 8,548 POSTS
It is either leaking it or burning it. Oil in the exhaust will destroy the CAT.
Have a compression test performed on the engine.
Oct 4, 2008 at 1:02 AM
