2000 Toyota Corolla Engine sometimes stalls
50,000 MILES • 4 CYL • FWD • AUTOMATIC
AGENTG22
My engine sometimes stalls or is slow to go when I press on the gas from a complete stop. Do you think that this might be a problem with the fuel pump or the (electronic?) fuel injection?
Thanks,
G.
Jan 24, 2008 at 9:58 AM
  • 75,988 POSTS
You can start by checking the fuel pressure making sure its under specifications also the throttle position sensor closed/wide open throttle voltages to include the engine load sensors such as the MAF sensor/Airflow meter.
Jan 24, 2008 at 10:54 AM
