HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Noise
2000 Toyota Corolla engine noise
DAISONPOULOSE
MEMBER
2000 TOYOTA COROLLA
4 CYL
FWD
MANUAL
340,000 MILES
My toyota corolla engine making some strange noise like something scratching inside the engine.
Tuesday, September 30th, 2008 AT 1:27 PM
MMPRINCE4000
MECHANIC
Check all fluid levels, if OK, then inspect the serpentine belt, it may need to be replaced, especially after 340,000 miles!
Could also be a bearing on the tensioner, waterpump, alternator, AC compressor etc.
SPONSORED LINKS
Wednesday, October 1st, 2008 AT 8:59 AM
Please
login
or
register
to post a reply.
Related Engine Noise Content
2000 Toyota Corolla Fizzing Noise From Under The Hood...
I Had Recently Replaced Spark-plugs As Adviced By A Mechanic. Immediately After That, This Problem Has Started. Whenever I Try To...
Asked by
rockabs4
2000
TOYOTA COROLLA
GUIDE
Engine Noises
Today's car engines are designed with more complexity and moving parts than ever before. When you hear abnormal noises there is something wrong. Some high output engines...
2005 Toyota Corolla Noise Under The Hood
I Hear Some Noise Under The Hood After Driving The Car For 10+ Mins. It Sounds Like Bird Chirping.
Asked by
Rosenda Shum
1 ANSWER
2005
TOYOTA COROLLA
2001 Toyota Corolla Engine Noise And Very Very Bad...
Hello, My Engine Makes A Noise When I Accelerate In 3, 4, 5 Speed But Mostly It's Like Burning Spanking Bad And Performance Is Really...
Asked by
Peteryota
2001
TOYOTA COROLLA
Noise Coming From Under Hood
At First There Was A Quiet High Pitched Sound Almost Like When You Are Sharping An Ax Or Something On A Grinding Wheel. And Now It Is Making...
Asked by
Tiffany Rowland
1994
TOYOTA COROLLA
Engine Noise
I Have A 1993 Toyota Corolla And There Is A Ringing/chirping Noise Coming From Either My Engine Or Some Close To It, And At Time It Almost...
Asked by
immerser
1 ANSWER
1993
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Engine Oil Change and Filter Honda CR-V
Engine Overheating Warning Light
Coolant Leak Repair
Online car repair manuals
