2000 Toyota Corolla CV Joint
2000 TOYOTA COROLLA
CHRISPAUL
Drive Train Axles Bearings problem
2000 Toyota Corolla 4 cyl Front Wheel Drive Manual
How do I replace a cv joint? Do I need to replace both cv joints at the same time?
Nov 6, 2009 at 7:31 PM
MMPRINCE4000
  • 8,548 POSTS
It is best to replace the entire axle assembly, you have to remove the caliper, bracket, outer tie rod, lower ball joint.
Pull knuckle out to clear axle, pop axle out from trans, replace axle seal, installation is reverse of removal.
New CV axles cost about $70 from most autoparts stores.
Nov 6, 2009 at 9:49 PM
