2000 Toyota Corolla Code 0171
17,300 MILES • 4 CYL • FWD • AUTOMATIC
TONSAECHIN
I have a check engine light on with code p0171. I took it to autozone they said my car is not getting enough fuel, more of air than fuel. Also my engine is making some noise when i first start it on. i have a little bit of rattling sound. I'm trying to find out what cause it so i can fix it. Please let me know thanks.
Oct 28, 2010 at 4:20 PM
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Oct 28, 2010 at 6:01 PM
MMPRINCE4000
  • 8,548 POSTS
P0171 indicates a lean condition bank one upstream O2 sensor.
This could be an O2 sensor, or a bad injector, low fuel pressure etc.
If original sensor, I would replace it and erase code.
Oct 28, 2010 at 10:54 PM
