2000 Toyota Corolla Check Engine light is not show, when ig
PRITHVI68
  • 2000 TOYOTA COROLLA
  • 4 CYL
  • 98,800 MILES
Two questions -
the check engine light does not show up, when the ignition key is inserted.
appreciate if you could give me options of what is wrong?
i need to get the vehicle inspected at NJ. Is this very important to pass vehicle inspection.
thanks in advance.
Friday, June 20th, 2008 AT 6:47 PM
MMPRINCE4000
  • 8,548 POSTS
When you turn the key to "on" the check engine light should illuminate to show the bulb is working.
Hopefully the bulb is burnt out and simply needs to be replaced.
Have the PCM scanned looking for any error codes. The instrument panel would have to be removed to get to the light.
It could also be the wiring to the light or a short/open circuit in the IP circuit board.
Check the fuses while your at it.
Saturday, June 21st, 2008 AT 7:46 AM
PRITHVI68
Thanks very much, for your reply.
That should help me very much, before proceeding to get the panel checked.
God bless.
Thanks.
Saturday, June 21st, 2008 AT 3:52 PM
TJEGZ
  • 10 POSTS
Thx.
Saturday, June 21st, 2008 AT 4:37 PM
