2000 Toyota Corolla AC rattles while idling
VHEIDE81
Air Conditioning problem
2000 Toyota Corolla 4 cyl Front Wheel Drive Automatic 215,000 kilometers
Recently my AC has started to rattle while the car is idling, but stops when I accelerate. When I turn the AC off completely, the rattling stops. The AC is still blowing cold. What is causing this?
Aug 17, 2009 at 6:21 AM
MMPRINCE4000
  • 8,548 POSTS
The AC clutch may be loose, remove belt, grasp clutch and see if you have any play. Also inspect compressor hold down bolts, make sure they are tight.
Aug 18, 2009 at 1:55 AM
