When I make a severe left turn I hear some clicking noises. It sounds like it's coming from the driver's side to the rear
Wednesday, May 6th, 2009 AT 4:22 PM
MMPRINCE4000
MECHANIC
Clicking when turning is almost always the front CV joints. If noise is coming from rear, then it would be a rear bearing.
Check front CV boots for rips/tears and leaking lubricant. If OK, then raise rear end, put on stands. Grasp tire and push/pull both horizontally and vertiically, looking for any movement.
Movement would indicate a bearing, since there is a clicking noise.
