1999 Toyota Corolla worth fixing?
SANDYK
Transmission problem
1999 Toyota Corolla 4 cyl Wheel Drive Type unknown Manual 160000 miles
99 corolla owned since new & regularly maintained. 5th gear just went but still able to use other 4 but can hear something rattling around when using them. Recently did $1500 of work replacing brakes & struts & new tires & all else seems good. Do you think it's worth fixing & how much could I expect to pay to repair (would you suggest used/rebuilt transmission)?
Feb 12, 2008 at 4:31 AM
MMPRINCE4000
  • 8,548 POSTS
Check the fluid level in the transmission, If none or low you can either rebuild or replace with used one.
I would get a used one and replace it. Check prices at local junk yards and installation prices at local garage's.
You are probably looking at $300-500 for the tranny and $700-1000 for install. Just remember that any garage that installs a used tranny will not warrant it, the junk yard warranty will be replacement only, not installation.
If you can find a local mechanic willing to do it in his garage, you may get it installed for $500 or so.
I installed an automatic in a 1991 for $500 and the guy paid $350 for a used tranny.
Feb 12, 2008 at 9:12 PM
