1999 Toyota Corolla Transmission problems
1999 TOYOTA COROLLA
15,000 MILES • 4 CYL • FWD • AUTOMATIC
FRANCES KELLY
My husband replaced the driver side axel and the car started to make a humming sound when driving the car,then the transmission stoped pulling.Seems like the cars trans will pull for little while then it stops pulling..What could be the problem???Also will a 99 camery transmission fit a 99 corolla? thanks
Dec 8, 2009 at 5:09 AM
MMPRINCE4000
  • 8,548 POSTS
Check differential fluid level in trans.
Look at transmission pan drain plug, if there is another drain plug directly behind it, then the differential fluid level is low/out as a result of axle change.
Dec 8, 2009 at 8:08 AM
