1999 Toyota Corolla Transmission cooler
110,000 MILES • 4 CYL • FWD • AUTOMATIC
KEVINWG
Hi, I am looking at adding an automatic transmission cooler to my Toyota Corolla 1999 with 110K miles. I am not towing anything, just want to do preventive things to extend the life of the transmission. My concern is whether it will put more strain on the pump that pushes the ATF through the additional pipes/tubes/plates in the cooler. Could it make that pump die sooner - thus reversing the intended effect of the cooler? Thanks!
Sep 24, 2010 at 3:48 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
This will not put a stress on the pump at all, the advantages will be all positive with the addition of a transmission cooler, fit one with confidence.
mark (mhpautos)
Sep 24, 2010 at 4:39 AM
