1999 Toyota Corolla Timing chain tensioner leaking
119,700 MILES • 4 CYL • 2WD • AUTOMATIC
MSHYAM
Hello sir,
Recently i did oil change for my car. The mechanic gave the below comment in the service log.
"Timing chain tensioner leaking oil"
When i asked him about this he said there is a minor leak. Do i need to fix it immediately? what will happen if not fixed. Also he gave estimate around 300 bucks.
I am worried whether it will cause any major service repair in the future. Currently my car is running good and no major problem i can notice.
Feb 17, 2010 at 11:11 AM
MMPRINCE4000
  • 8,548 POSTS
He will simply change the gasket. Timing chains are enclosed so engine oil will lubricate chain.
If it is a minor leak, then it is not an emergency, but I would have it repaired as soon as you can.
Also check engine oil level more frequently, at least once a week.
While the gasket is not expensive, you must remove a lot of parts to get to chain cover, so $300 is reasonable.
Feb 17, 2010 at 10:18 PM
