1999 Toyota Corolla Starting problem
MRSHANIM
  • 1999 TOYOTA COROLLA
1999 Toyota Corolla 4 cyl Automatic 121000 miles
When I crank for starting car, firstly it didn't move to starter, means only knock sound appears. No movement in the starter motor. My battery is fine. After some attempt If got connection to starter, some movement in starter and car starts. But not sure why it knocks in first few attempts. THe longer car is unused(some hrs), chances are high facing this knocks.
I thought it would be corrosion, but my headlights, radio, and other stuff is working fine(even before start). NO message on the display also.
Regards
Saturday, May 15th, 2010 AT 11:53 AM
MMPRINCE4000
  • 8,548 POSTS
Take car to autoparts store and have battery and charging system tested.
Sunday, May 16th, 2010 AT 8:05 AM
MRSHANIM
Already tested my battery and charger. Both are working fine.
Sunday, May 16th, 2010 AT 9:06 AM
MMPRINCE4000
  • 8,548 POSTS
Check connections to starter, make sure they are clean and tight, if problem persists. Remove starter and have it bench tested.
Monday, May 17th, 2010 AT 9:40 AM
