1999 Toyota Corolla starter problem
51,000 MILES • 4 CYL • FWD • AUTOMATIC
ALFONSOOM
I have a 1999 toyota corolla with 51,000 miles on it. During the last few days, when I turn the ignition key to stat the car sometimes it just doesn't start the first time or the second time. I check the interior and head lights and it seems there is enough current in the battery. Somebody told me that this maybe a starter problem. Do you think this is the case, and if it is, how I can change the starter. Thank you for your help. Alfonso
May 12, 2008 at 9:20 AM
  • 75,988 POSTS
Do you have a check engine light and when was the last major tune-up?
Do you mean it cranks over and refuses to start at times or won't crank engine over sometimes?
May 12, 2008 at 10:19 AM
ALFONSOOM
[quote="alfonsoom"]Engine Mechanical problem
1999 Toyota Corolla 4 cyl Front Wheel Drive Automatic 51000 miles
I haven't seen the engine light come on and I did the major tune up when the car had 30,000 miles.
When I turn the key the first time, the car doesn't do anything. The second time it cranks over but refuses to start. The third I turn the key the car starts like if there was no problem with it. Sometimes it starts at the second time I turn the key.
May 12, 2008 at 12:12 PM
BRUIZER
  • 35 POSTS
sounds like the starter solenoid....may have dirty or faulty contacts in starter.
May 12, 2008 at 12:34 PM
