1999 Toyota Corolla Stability
110,000 MILES • 4 CYL • FWD • AUTOMATIC
PATCHES10025
Car has recently become less secure on bumps and generally feels like the steering is a bit less firm so that the car does not give quite the stability it had. Also I have noticed a minor thump when it goes over a bumpy road.
Apr 28, 2009 at 7:35 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Apr 29, 2009 at 10:28 PM
