1999 Toyota Corolla shifter
1999 TOYOTA COROLLA
119,000 MILES • 4 CYL • FWD • AUTOMATIC
BRUCE STANSFIELD
when i press on brake pedal to shift the button on side of shifter wont disengage.i checked brake lights are working. all fuses are good.i am using the small override button to drive the car.need help.
Sep 17, 2010 at 1:54 AM
WRENCHTECH
  • 20,761 POSTS
If you have verified that the brake lights are working, then your probably looking at a bad actuator solenoid and it would have to be access and tested first.
Sep 17, 2010 at 2:05 AM
