1999 Toyota Corolla Rear Windscreen Wiper
60,000 MILES • 4 CYL • FWD • MANUAL
COLIN BARR
All of a sudden last week the rear windscreen wiper has come on all the time in my car. Can't switch it off at any point on control switch. Front windscreen wiper which is oprated from the same control stock is working fine and can be switched off & on ok. Just a problem with the rear. Only way rear windcreen wiper will go off is when ignition switched off. I eventually had to disconnect the lead to the rear screen wiper directly from within the hatch-back so am currently without the use of the rear wiper..Model is a 1999 1300SE 5 door hatchback. Any guidance as to this probelem would be appreciated. I have a new battery and the alternator was checked at the time this was fitted and was tested as ok.
Feb 22, 2010 at 6:51 AM
  • 31,937 POSTS
Hi there,
I would be thinking that you have a faulty switch or a faulty relay, i must say that just now my data base is down so i cant check for any relay location, your local dealer may have this information at hand for you, if i get it back on line soon i will post again.
Mark (mhpautos)
Feb 22, 2010 at 8:27 AM
