1999 Toyota Corolla LOUD BANGS
84,000 MILES • 4 CYL • FWD • AUTOMATIC
KATHYKAT56
everytime my car hits a small bump even a sewer cover the noise it makes is almost unbearable. It is mostly coming from the back passenger side right by the tire. I notice when the temperature goes down it will do it but when it warms up it doesnt. Last time I had it checked they said i need struts. Is this noise a result of the struts? Or do you think something else is causing this? Why does the real cold weather make this happen? It is so bad it seems that i dont have any shocks on that side. thank you kathy
Feb 16, 2010 at 12:42 AM
MMPRINCE4000
  • 8,548 POSTS
Heat and cold expand and contract metal and can cause more/less noise depending on where contact failure is.
Have rear struts replaced and have strut mounts inspected, it is unususal for a Toyota to need struts this soon, unless wrecked.
Feb 16, 2010 at 7:56 AM
