1999 Toyota Corolla i can't seem to figure it out
123,000 MILES • 4 CYL • 2WD • AUTOMATIC
GRADSTUDENTWITHNOMONEY
My car had been running great since I bought it 2 years ago. Last summer I had 4 gallons of water put into my gas tank because someone mistakenly put water in a 5 gallon gas drum and forgot to tell me. I drained the tank and the car ran fine after that. About 6 months later the engine started running weird. It idles fine but when I accelerate it starts to sound like the engine is getting choked out, it sputters and then when i press the pedal to the floor it seems to "punch out" of the problem it has. I bought some iridium spark plugs and replaced my plugs. The problem was 100% immediately fixed, and i was happy as heck. But about 3 weeks later the same problems started coming back. What do you think the issue is?
Apr 12, 2008 at 8:35 AM
  • 75,988 POSTS
Check the throttle position and MAF sensor also get the fuel pressure tested and have the computer scanned for code/s with or w/o the check engine light
Apr 12, 2008 at 11:04 AM
I figured out what it was......it was the wiring pack going to each spark plug. that needed to be replaced. $ 50
Apr 16, 2008 at 1:03 PM
