1986 Toyota Corolla possible Fuel Starvation problem
BEN GREYLING
Engine Performance problem
1986 Toyota Corolla 4 cyl Two Wheel Drive Manual
My vehicle has a constant problem regarding I think is a fuel starvation problem. Only while driving, not idiling, it sometimes feels like it is being starved and pulls negatively. I have cleaned my fuel tank out. Cleaned the fuellines and injectors, changed filters, serviced my carburator. Basically every possible item i could think of was either serviced replaced and or cleaned. I still suffer form this. It has new poins spark plugs, Bougi cords, etc in as well. Please can someone assist in helping me sorting this out.
Kind Regards
Ben Greyling
Mar 12, 2010 at 10:04 AM
  • 75,988 POSTS
Is it a carbuerated or an EFI fuel system I'm lil confused here.
Mar 12, 2010 at 10:19 AM
BEN GREYLING
It is a carburated fuel system.. Thnx for the reply
Mar 13, 2010 at 4:16 AM
  • 75,988 POSTS
Okay -adjust the point gap and then the ignition timing-both okay check the fuel pressure to rule out the fuel filter and fuel pump.Also check if the clutch is slipping, get back with some results.
Mar 13, 2010 at 4:30 AM
BEN GREYLING
THnx for the help.. Definatly not the clutch.. But i will look at the other parts..Maybe the damm thing slipped at some stage...
I will have a look when I get back..Currently out of the country but will get back with feeback
Thnx
Mar 13, 2010 at 4:38 AM
