1999 Toyota Corolla Gas Gauge
111,000 MILES • 4 CYL • 2WD • AUTOMATIC
PUNEETSHARMA
I have 1999 toyota Corolla, Mileage - 111000. Gas Gauge of the car is stuck at the bottom (NO GAS!!!) and I have been driving the car with no problem but have to keep track of the mileage on the trip meter. What should be causing it and how much will it cost to fix this problem.
Thanks.
Mar 16, 2009 at 4:03 AM
MMPRINCE4000
  • 8,548 POSTS
You are not getting a signal from sender in tank. Check connections at tank, if OK then sender or gauge is bad.
Mar 17, 2009 at 12:25 AM
