1999 Toyota Corolla cooling fan
1999 TOYOTA COROLLA
134,000 MILES • 4 CYL • FWD • AUTOMATIC
LUIS1976
I would like to know what to look for if the cooling fan on my vehicle is not working. I replaced the water sensor and the relay for the fans, but it still does not work. I checked the power in the relay compartment and it does not have power. I would like to know if it has something to do with the computer?
Oct 26, 2008 at 10:53 AM
Hi luis1976 and welcome to 2carpros Check the RDI fuse 30amp it powers the fan relay, also the fan circuit is not tied in with the computer
https://images.2carpros.com/forum/automotive_pictures/12900_cf1_10.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_cf2_10.jpg
Good Luck
Oct 26, 2008 at 10:28 PM
LUIS1976
[quote:c871062169="luis1976"]Engine Cooling problem
1999 Toyota Corolla 4 cyl Front Wheel Drive Automatic 134000 miles
I would like to know what to look for if the cooling fan on my vehicle is not working. I replaced the water sensor and the relay for the fans, but it still does not work. I checked the power in the relay compartment and it does not have power. I would like to know if it has something to do with the computer?[/quote:c871062169]
I checked the circuit fuse (30 amp), the fuse is good but the fuse compartment does not have power. What else can I check and I also I would like to know why the whole fuse compartment does not have power at all?
Oct 27, 2008 at 6:17 AM
Find the power distribution box and test all those squared colored box called fusible links-power has to go thru this links before it goes anywhere-Its like the your house main breaker
Oct 27, 2008 at 8:03 AM
