1999 Toyota Corolla Check Engine Light Code P0441
200,000 MILES • 4 CYL • FWD • MANUAL
ERIDDLE13
My check engine light came on last week and I had it tested at Auto Zone, who informed me of the P0441 code that came up as the problem. P0441 is "Evaporative emission control system incorrect purge flow; probable cause (1) Leak in EVAP system, (2) Blocked EVAP purge line, or (3) Faulty purge VSV."
I've been doing a lot of research regarding this common problem online and have come up with a ton of different answers (for example - check for damage to gas cap/hoses/valves in emissions system, replace faulty VSV and/or PCV valve, replace evaporative emissions canister, etc.). Any thoughts where I should start or resources to help me in this repair venture?
Thanks!
Mar 29, 2010 at 6:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check vacuum hose at air cleaner housing, gets knocked loose often during oil changes.
Mar 29, 2010 at 8:37 AM
