1999 Toyota Corolla brake nut size
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
AUGGIEDOG44
Trying to remove rotors and looks like a nut holding them on is about 1 1/4 inch. maybe 27mm. do you know what size the nut is so I can get a socket that size? never had this problem with previous Toyota's.
Aug 28, 2010 at 8:59 AM
MMPRINCE4000
  • 8,548 POSTS
Go to local Advance Auto and rent a axle nut socket set, 30,32,34,36mm. You will get all your money back once you return it.
Aug 29, 2010 at 1:18 AM
