1998 Toyota Corolla Wheel Bearing
MAYFAIR
  • 1998 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 246,000 MILES
I had a friend replace my left front wheel bearing 11/08. My car failed inspection 5/09 for same wheel bearing. Replaced it, passed inspection. Left front tire area was making noise, thought maybe tire was out of balance and took it to be looked at and was told my bearing was bad. Is there something that could be going on with my car that is causing the bearing to keep going bad? Thanks for your help. Carolyn
Friday, September 18th, 2009 AT 7:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Faulty suspension components or misalignment can cause premature wheel bearing failure. Have the suspension components and wheel alignment checked to ensure none are weak and need replaced or realigned.
Friday, September 18th, 2009 AT 10:57 AM
