1998 Toyota Corolla My Corolla
GIN_AS_IN_BIRD
  • 1998 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 165,000 MILES
My corolla is making a nasty grinding sound when I turn left. I only hear the noise when I am driving at lower speeds.
I've had the wheel bearing replaced (a month ago) and I've had the power steering fluid level checked
Thursday, November 5th, 2009 AT 10:17 AM
Get that side driveaxle checked out-CV joint/boot problem and recheck wheel bearing
Thursday, November 5th, 2009 AT 11:23 AM
EDWARD 18
CHECK THE CV JOINT ON RIGHT
Saturday, November 7th, 2009 AT 10:13 AM
MMPRINCE4000
  • 8,548 POSTS
Look at outer CV boots, check for tears/leaking lubricant.
CV axles fail (generally) because the boots get torn by road debris and lubricant leaks out and allows water in, causing eventual metal to metal contact and joint failure.
Under the right conditions, it can sieze.
Sunday, November 8th, 2009 AT 8:23 AM
