1998 Toyota Corolla Steering wheel shakes
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAMESBOND007
My steering wheels shakes at high speeds like 70mph and car shakes too much (when compared to other cars)when going through uneven roads. I took it to a auto-repair shop, they checked it and said its due to my inner tire rod ends & the estimate for fixing it is upto $400. and another repair shop told me it might be due to tire balance problems. I called Toyota dealers and they said inner tire rod ends rarely have a problem and he has never seen any car having that problem till now.
What do you think the problem might be due to? Am I getting ripped off by these stores?
May 12, 2008 at 5:51 AM
MMPRINCE4000
  • 8,548 POSTS
Jack up the front end and grasp the tire and pull horizontally and vertically looking for any movement, if none then tires are out of balance or camber/toe-in.
If you have movement it could be inner/outer tie rods, ball joints, or bearings.
May 13, 2008 at 12:48 AM
