1998 Toyota Corolla Starter
70,000 MILES • 4 CYL • FWD • AUTOMATIC
CLUEMAN
I am changing the starter in a 1998 toyota corolla
It's under the exhaust Manifold. I can get bottom bolt and wires np. What is the trick to getting the top bolt outside of taking manifold off???
Ideas would be great..
Paul
Mar 7, 2008 at 9:35 AM
BLACKOP555
  • 10,386 POSTS
I usually take off the exhaust manifold other then messing around with trying to get around it, you may be able to get a box end ratcheting wrench up on there or if you have ratchets that the head pivots you may be able to.
Mar 7, 2008 at 11:31 AM
