1998 Toyota Corolla Some rubbing/grinding noise at the spee
28,000 MILES • 4 CYL • FWD • MANUAL
SHRINIVEL
  • 5 POSTS
Recently I abserved some vibration in my corolla then I gone to workshop then they suspect wheel bearing problem then they repalaced front whell(both) bearing and break shoe also replced,disc cleaned.Now no vibration but some rubbing/grinding noise is there while raising speed of 30kmph and also while slow down from high speed.But no sound till 30 and above 30.Then I again gone to workshop but they are confusing me telling that it may from gear or clutch.Please advice me. Please note that two months before I changed all new tyres and clutch disc. All cv joint and ball joints are ok.But still streering wheel shakes at 120-130 kmp.
Jun 5, 2009 at 3:20 AM
MMPRINCE4000
  • 8,548 POSTS
Try this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Also check trans. fluid level and diffferential fluid level.
Jun 6, 2009 at 1:50 AM
