Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Oxygen Sensor
Replace/Remove
1998 Toyota Corolla REPLACING O2 SENSOR
1998 TOYOTA COROLLA
192,000 MILES • 4 CYL • FWD • MANUAL
MYSTICBLUE98LE
MEMBER
1 POST
CAN I REPLACE A CATALYTIC CONVERTER AND A O2 SENSOR MYSELF AND IF SO WHAT DO I NEED AND IS IT WORTH DOING IT MYSELF
Sep 7, 2010 at 11:50 AM
MMPRINCE4000
Experienced Mechanic
Many Toyota convertors are bolted in, if so, unbolt and replace. If welded in, then a shop will have to remove and re-weld.
The O2 sensor screws into a bung in exhaust. Disconnect and unscrew.
Sep 8, 2010 at 12:49 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
