Hi, sometimes when I start the car, I just get a clicking noise; sometimes the first time it starts fine. I have already checked the battery and cable connections to the battery. I noticed if I pump the gas pedal and/or push the gas pedal down while I'm cranking the engine, the engine starts. At least this trick works everytime the first or second try. What can be the problem here?
Thank you in advance.
Aug 4, 2009 at 5:33 AM
