Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Steering
Hose
Replace/Remove
1998 Toyota Corolla power steering hoses
1998 TOYOTA COROLLA
165,000 MILES • 4 CYL • FWD • AUTOMATIC
MILLINWAT1
MEMBER
1 POST
How do I remove the power steering pressure hoses from the back of the power steering pump?
Jul 6, 2008 at 2:46 AM
MMPRINCE4000
Experienced Mechanic
Look at the bolt that holds the high pressure hose to the pump, if it has a female "star" shape, it is a Torx bolt and you would need a Torx bit.
Take it to an auto parts store and ask them to find out what torx size it is (T-50 for example).
Low pressure (return) hose is usually held by a clamp.
Jul 6, 2008 at 10:59 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
