1998 Toyota Corolla Nasty noises coming from the front end
160,000 MILES • 4 CYL • FWD • AUTOMATIC
GIN_AS_IN_BIRD
I have a nasty noise when I turn left. I only hear this sound at lower speeds. I have already had the wheel bearing replaced. (about a month ago)
Any ideas what it could be?
Nov 5, 2009 at 2:21 AM
MMPRINCE4000
  • 8,548 POSTS
Try this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Whoever replaced the bearing should have checked the ball joint, bushings, tie rods, control arm etc.
Nov 5, 2009 at 11:12 PM
