1998 Toyota Corolla MAKES LOAD NATTLING NOISE NEAR OIL PAN
104,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGSHO127
had a used engine put in the car its a 16 valve EFI the motor makes a load rattling noise near the oil pan. and you can hear it from the top with the hood open. have driven it up the road and on the highway, it doesn't seem to have a loss of power when stepping on the accelerator. How could i access the problem?
May 10, 2010 at 4:47 AM
MMPRINCE4000
  • 8,548 POSTS
Start by trying a higher octane gas to rule out pre-ingition.
If problem persists, you will have to remove oil pan and inspect rod and main bearings.
May 12, 2010 at 1:50 AM
