1998 Toyota Corolla LOUD SNAP AND THE ENGINE WON' TURN OVER
EDDIE53
  • 1998 TOYOTA COROLLA
Electrical problem
1998 Toyota Corolla 4 cyl Two Wheel Drive Automatic 120K miles
Had the starter out and checked. Passed 3 times good. Changed the battery (new). Had the system checked at Pep boys. All checked good. Cleaned every conection from batt to starter.
When you turn the key you get a loud snap but does not start.I'm trying to avoid the $65 / hr. To diagnose.
Any suggestions?
Thanks
Ed
Monday, October 6th, 2008 AT 4:31 PM
MMPRINCE4000
  • 8,548 POSTS
The loud snap sounds like an electrical arc. The starter wire is too close to the block (which is a ground).
Check the power cable to the starter is not close to block and does not have any open insulation.
Wednesday, October 8th, 2008 AT 7:26 AM
EDDIE53
Thanks.I'll check that and let you know
Best regards
Ed
Wednesday, October 8th, 2008 AT 10:33 AM
EDDIE53
Would I be able to see the arc. Lets say at night ( in the dark) if there is one?
Checked the cords and there aren't any cuts visable anywhere
the cord itself from the battery actually has a clamp that holds it against the block !? Then runs over to the starter
Monday, October 13th, 2008 AT 2:43 PM
MMPRINCE4000
  • 8,548 POSTS
You should be able to see it. It could also be a bad relay, or possibly the ign. Switch.
Tuesday, October 14th, 2008 AT 6:07 AM
EDDIE53
Thanks
I'll check those next
Best regards
Tuesday, October 14th, 2008 AT 10:36 AM
EDDIE53
Thanks for all of your help. Turns out the starter is no good. Had it re-checkred again at Kragen this time. So keep in mind that just because it may test good. It may not be good. Installed the new one and it works great.
Thanks again
best regards
Ed
Thursday, October 16th, 2008 AT 4:12 PM
