1998 Toyota Corolla Interior
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
DLOSH
I have two questions:
How do I access the in dash light bulbs? They are burnt out. The gear shift one is too but I guess that is expensive to replace.
My interior molding (trim) fell off. Near the windshield, above the door. What parts do I need to put is back on? It looks like there are some kind of stud and groove thing going to snap it back on.
Apr 8, 2009 at 1:57 AM
MMPRINCE4000
  • 8,548 POSTS
You have to remove the instrument panel to replace lights, but check the dimmer switch and fuses, it would be rare for all the lights to fail at once.
The trim panel snaps into retainers, if missing a retainer you can get new ones from Toyota, also make sure the trim panel does not have any broken plastic parts.
Apr 9, 2009 at 2:43 AM
PMP
  • 177 POSTS
the gear shift one isnt expensive you have to take certain stuff off its really not that bad. how much is someone chargin you for it its a really tiny bulb also.
Apr 10, 2009 at 1:56 PM
