Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Tires
Replace/Remove
1998 Toyota Corolla how to change tire
1998 TOYOTA COROLLA
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAYVIC463
MEMBER
1 POST
how to remove tire behind the driver side
Oct 7, 2008 at 5:21 AM
MMPRINCE4000
Experienced Mechanic
Loosen the wheel lugs before you jack up car (just a half turn).
Jack up car, remove the wheel cover (if equipped) remove lugs, tire.
If you have aluminum sport wheels they need to be torqued to 65-80ft.lbs. This is important.
Oct 8, 2008 at 12:16 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
