code P0441
182,000 MILES • 4 CYL • FWD • AUTOMATIC
RANDEEP
I'm getting code P0441 and wondering which component to replace first the VSV for EVAP, VSV for Vapor Pressure Sensor or the Vapor Pressure Sensor itself. If I just start replacing parts which one is more likely to fix it. Thank You!!!
Oct 4, 2009 at 8:35 AM
There are a number of things that this can be, so we need to start with running through this DTC testing that I attached below.
However, here is a guide that will help with checking vacuum hoses for leaks:
Below is the testing that we need to run through. Basically, we have a possible VSV, hose, wiring connection, or even the ECM. So, let's run through this testing and see what we can find.
Let me know what questions you have. Thanks
Jan 30, 2022 at 9:02 AM
