what is the correct procedure for replacing the serpentine engine belt
Mar 20, 2008 at 9:53 AM
BMRFIXIT
✓Experienced Mechanic
You have a self adjusting tensioner
check the red marking
that is the direction for it to loosen
once tension removed then belt can be removed
good luck
