HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Serpentine Belt
Replace/Remove
1998 Toyota Corolla belt replacement
FELYCD
MEMBER
1998 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
126,000 MILES
What is the correct procedure for replacing the serpentine engine belt
Thursday, March 20th, 2008 AT 4:53 PM
BMRFIXIT
MECHANIC
You have a self adjusting tensioner
check the red marking
that is the direction for it to loosen
once tension removed then belt can be removed
good luck
Thursday, March 20th, 2008 AT 5:33 PM
Please
login
or
register
to post a reply.
Related Serpentine Belt Replace/Remove Content
1998 Toyota Corolla
Engine Mechanical Problem 1998 Toyota Corolla 4 Cyl Two Wheel Drive Automatic I Replaced The Drive Belt In Accordance A Belt Routing...
Asked by
ee4666
1 ANSWER
1998
TOYOTA COROLLA
VIDEO
How to Replace Serpentine Belt Toyota Prius
Instructional repair video
GUIDE
Serpentine Belt Replacement
Need to change your serpentine belt? This is an easy job in most cases. There are several names used to describe a serpentine belt, including: drive belt, poly-v belt, multi...
1998 Toyota Corolla Serpentine Belt
The Serpentine Belt On My 1998 Toyota Corolla Ce Is Cracked And I Need To Buy A New One To Replace It. I Am Just Wondering Exactly Which...
Asked by
dkarstedt
1 ANSWER
1998
TOYOTA COROLLA
How To Remove Power Steering Belt?
Steering Problem 4 Cyl Front Wheel Drive Automatic 89375 Miles I Am Trying To Loosen Power Steering Reservior In Order To Remove Old...
Asked by
wangzhe18
1 IMAGE
1996
TOYOTA COROLLA
Serpentine Belt
The Serpentine Belt Is Making A Constant Squeaking Noise. It Has Small Cracks All Over The Belt, No Chunks Are Missing And No Threads Are...
Asked by
roundingthird
1 IMAGE
2006
TOYOTA COROLLA
1996 Toyota Corolla Serpintine Belt
My Problem Is I Took All 3 Bolts Out When I Replaced The Belt. And When I Took The Alternator Out, There Were 2 Wires That Looked Like They...
Asked by
ChicagoShagz
5 IMAGES
1996
TOYOTA COROLLA
VIEW MORE
Serpentine Belt Replacement Saturn Vue
Serpentine Belt Change Acura TL 2004-2008
Serpentine Belt Replacement Mercedes Benz
