Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Brakes
Symptoms
Lock Up
1998 Toyota Corolla
1998 TOYOTA COROLLA
11,000 MILES • 4 CYL • FWD • MANUAL
JAKESLEG63
MEMBER
1 POST
the front driver side brake keeps sticking it will lock completely and you cant move the car at all
Oct 5, 2010 at 3:00 AM
Experienced Mechanic
Check the brake caliper piston could be corroded and also the brake hose if its collasped internally acting as a one way check valve
Oct 5, 2010 at 3:03 AM
MMPRINCE4000
Remove caliper and inspect slide pins. If siezed, replace caliper.
Oct 5, 2010 at 3:04 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
